Manage Microsoft SQL Server inventory with NetApp Backup and Recovery
Contributors guillermotome
View and manage Microsoft SQL Server hosts, instances, and databases, and change or remove their protection settings.
You can do the following to manage your inventory:
  • Manage host information
    • Suspend schedules
    • Edit or delete hosts
  • Manage instance information
    • Associate credentials with a resource
    • Back up now by starting an on-demand backup
    • Edit protection settings
  • Manage database information
    • Protect databases
    • Restore databases
  • Configure the log directory from Inventory > Hosts before you back up database host logs in snapshots. For details, see Configure NetApp Backup and Recovery settings.
Manage host information to ensure that the right hosts are protected. View, edit, and delete host information as needed.
Required NetApp Console role
Backup and Recovery super admin, Backup and Recovery backup admin, Backup and Recovery restore admin, or Backup and Recovery clone admin role. If you are protecting data stored on a Cloud Volumes ONTAP cluster, the Cloud Volumes ONTAP Admin role is also required. Learn about NetApp Console access roles for all services.
Manage hosts
You can manage the hosts that are discovered in your system, individually or as a group.
Tip To manage a host, look for an "Unmanaged" status in the Hosts column. NetApp Backup and Recovery already manages hosts with a "Managed" status.
After you manage the hosts in NetApp Backup and Recovery, SnapCenter no longer manages the resources on those hosts.
Backup and Recovery super admin or Backup and Recovery backup admin. If you are protecting data stored on a Cloud Volumes ONTAP cluster, the Cloud Volumes ONTAP Admin role is also required. Learn about NetApp Console access roles for all services.
Steps
  1. From the menu, select Inventory.
  2. Select a workload to view the protection details.
  3. Select the Actions icon Actions option > View details.
  4. Select the Hosts tab.
  5. Select one or more hosts. If you select multiple hosts, a Bulk actions option appears. Select Manage (up to 5 hosts).
  6. Select the Actions icon Actions option > Manage.
  7. Review the host dependencies:
    • If the vCenter does not display, select the pencil icon to add or edit the vCenter details.
    • If you add a vCenter, you must also register the vCenter by selecting Register vCenter.
  8. Select Validate settings to test your settings.
  9. Select Manage to manage the host.
Suspend schedules
Suspend schedules to stop backup and restore operations during host maintenance.
Steps
  1. From the NetApp Backup and Recovery menu, select Inventory.
  2. Select the host on which you want to suspend schedules.
  3. Select the Actions Actions icon icon, and select Suspend schedules.
  4. In the confirmation dialog box, select Suspend.
Edit a host
You can change the vCenter server information, host registration credentials, and advanced settings.
Steps
  2. Select the host that you want to edit.
  3. Select the Actions Actions icon icon, and select Edit host.
  4. Edit the host information.
  5. Select Done.
Delete a host
You can delete the host information to stop service charges.
Steps
  2. Select the host that you want to delete.
  3. Select the Actions Actions icon icon, and select Delete host.
  4. Review the confirmation information and select Delete.
Manage availability group information
Manage availability group information to protect resources, edit protection settings, and run backups:
  • Protect instances
  • Back up now
Backup and Recovery super admin or Backup and Recovery backup admin role. If you are protecting data stored on a Cloud Volumes ONTAP cluster, the Cloud Volumes ONTAP Admin role is also required. Learn about NetApp Console access roles for all services.
Protect availability groups
Assign a policy to an availability group to govern the schedule and retention of resource protection.
Steps
  2. Select the workload that you want to view and select View.
  3. Select the Availability groups tab.
  4. Select the availability group.
  5. Select the Actions Actions icon icon, and select Protect.
  6. Select a policy or create a new one.
    For details about creating a policy, see Create a policy.
  7. Provide the scripts to run before and after the backup.
    • Pre-script: Enter the script filename and location to run automatically before the protect action starts. Use this to perform additional tasks or configurations before the protection workflow.
    • Post-script: Enter the script filename and location to run automatically after the protection action completes. Use this to perform additional tasks or configurations after the protection workflow.
Manage instance information to protect resources, associate or remove credentials, edit protection settings, and run backups:
  • Protect instances
  • Disassociate credentials
  • Back up now
Protect database instances
Assign a policy to a database instance to govern the schedule and retention of resource protection.
Steps
  3. Select the Instances tab.
  4. Select the instance.
  8. Provide verification information for the snapshot:
    • Storage location: Select where to store the verification snapshot.
    • Verification resource: Select whether to verify the resource on the local snapshot, on ONTAP secondary storage, or both.
    • Verification schedule: Select the frequency: hourly, daily, weekly, monthly, or yearly.
You can associate credentials with a resource so protection can occur.
Steps
  5. Select the Actions Actions icon icon, and select Associate credentials.
  6. Use existing credentials or create new ones.
You can change the policy, create a new policy, set a schedule, and set retention settings.
Steps
  5. Select the Actions Actions icon icon, and select Edit protection.
Back up now
Back up your data now to protect it immediately.
Steps
  5. Select the Actions Actions icon icon, and select Back up now.
  6. Choose the backup type and set the schedule.
    For details about creating an ad hoc backup, see Back up Microsoft SQL Server workloads.
You can manage database information in the following ways:
  • Protect databases
  • Restore databases
  • View protection details
  • Back up now
Protect databases
Steps
  3. Select the Databases tab.
  4. Select the database.
  6. Provide the scripts to run before and after the backup.
Restore databases
Restore a database when you need to recover data.
Backup and Recovery super admin or Backup and Recovery restore admin role. If you are protecting data stored on a Cloud Volumes ONTAP cluster, the Cloud Volumes ONTAP Admin role is also required. Learn about NetApp Console access roles for all services.
Steps
  5. Select the Actions Actions icon icon, and select Restore.
    For information about restoring workloads, see Restore workloads.
Backup and Recovery super admin or Backup and Recovery backup admin role. Learn about NetApp Console access roles for all services.
Steps
Back up now
You can back up your Microsoft SQL Server instances and databases now to protect your data immediately.
Steps
  3. Select the Instances or Databases tab.
  4. Select the instance or database.
