Protect Microsoft SQL Server workloads with NetApp Backup and Recovery
Contributors guillermotome
Back up Microsoft SQL Server databases from on-premises ONTAP systems to AWS, Azure, or StorageGRID using NetApp Backup and Recovery. Implement a 3-2-1 backup strategy with snapshots on primary storage, replication to secondary storage, and copies to object storage.
NetApp Backup and Recovery uses NetApp SnapMirror to synchronize backups by creating snapshots and transferring them to the backup locations.
Use the following workflows to protect your data:
To back up workloads, you create policies that manage backup and restore operations. See Create policies for more information.
Supported backup destinations
NetApp Backup and Recovery supports backups of Microsoft SQL Server instances and databases from the following source systems to the listed secondary systems and object stores in public and private clouds. Snapshots remain on the source system.
Source system Secondary system (replication) Destination object store (backup)
Cloud Volumes ONTAP in AWS
On-premises ONTAP system
Amazon S3
ONTAP S3
Cloud Volumes ONTAP in Azure
Azure Blob
ONTAP S3
Cloud Volumes ONTAP
Amazon S3
Azure Blob
NetApp StorageGRID
ONTAP S3
Amazon FSx for NetApp ONTAP
NA
Supported restore destinations
You can restore Microsoft SQL Server instances and databases from a backup that resides in primary storage, a secondary system (replicated volume), or object storage (backup file) to the following destination systems. Snapshots reside on the source system and can be restored only to that same system.
From backup file location To destination system
Object store (backup)
Amazon S3
ONTAP S3
Azure Blob
ONTAP S3
StorageGRID
Cloud Volumes ONTAP
ONTAP S3
Note References to "on-premises ONTAP systems" include FAS and AFF systems.
