ONTAP data restore options in NetApp Backup and Recovery
Contributors guillermotome
Use NetApp Backup and Recovery to restore your ONTAP volume data from snapshots, replicated volumes, or object storage at a specific point in time. You can restore an entire volume, a folder, or individual files as needed.
Note When you restore a SnapLock-enabled volume, the restored volume retains SnapLock protection only if the destination storage is WORM-enabled. If you restore to a non-WORM destination, the SnapLock status is removed from the restored volume.
  • You can restore a volume (as a new volume) to the original system, to a different system that's using the same cloud account, or to an on-premises ONTAP system.
  • You can restore a folder from a replicated volume or an object storage backup to a volume in the original system, to a volume in a different system that's using the same cloud account, or to a volume on an on-premises ONTAP system. Restoring folders from local snapshots is not supported.
  • You can restore files to a volume in the original system, to a volume in a different system that's using the same cloud account, or to a volume on an on-premises ONTAP system.
You need a valid NetApp Backup and Recovery license to restore data to a production system.
To summarize, these are the valid flows you can use to restore volume data to an ONTAP system:
  • Backup file → restored volume
  • Replicated volume → restored volume
  • Snapshot → restored volume
Note If the restore operation does not complete, wait until the Job Monitor shows "Failed" before you retry the restore operation.
Note For limitations related to restoring ONTAP data, see Backup and restore limitations for ONTAP volumes.
The restore dashboard
You use the Restore Dashboard to perform volume, folder, and file restore operations. To access the Restore Dashboard, select Backup and recovery from the Console menu, and then select the Restore tab. You can also select More button > View Restore Dashboard from the Backup and recovery service from the Services panel.
Note NetApp Backup and Recovery must already be activated for at least one system and initial backup files must exist.
The Restore Dashboard provides two different ways to restore data from backup files: Browse & Restore and Search & Restore.
Compare Browse & Restore and Search & Restore
In broad terms, Browse & Restore is typically better when you need to restore a specific volume, folder, or file from the last week or month and you know the name and location of the file and the date when it was last in good shape. Search & Restore is typically better when you need to restore a volume, folder, or file, but you don't remember the exact name, the volume in which it resides, or the date when it was last in good shape.
This table provides a feature comparison of the two methods.
Browse & Restore Search & Restore
Browse through a folder-style structure to find the volume, folder, or file within a single backup file.
Search for a volume, folder, or file across all backup files by partial or full volume name, partial or full folder/file name, size range, and additional search filters.
Does not handle file recovery if the file has been deleted or renamed and you don't know the original file name
Handles newly created, deleted, and renamed directories and files
Quick restore is supported.
Quick restore is not supported.
This table provides a list of valid restore operations based on the location where your backup files reside.
Backup Type Browse & Restore Search & Restore
Restore volume
Restore files
Restore folder
Restore volume
Restore files
Restore folder
Snapshot
Yes
No
No
Yes
Yes
Yes
Replicated volume
Yes
No
No
Yes
Yes
Yes
Backup file
Yes
Yes
Yes
Yes
Yes
Yes
Before you use either restore method, configure your environment to meet the resource requirements. See the following sections for details.
See the requirements and restore steps for the type of restore operation you want to use:
