SANtricity commands
Clear volume reservations - SANtricity CLI
Contributors netapp-driley
The clear volume reservations command clears persistent volume reservations.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
clear (allVolumes | volume [volumeName] |
volumes ["volumeName1" ... "volumeNameN"]) reservations
Parameter Description
allVolumes
The setting to clear persistent volume reservations on all of the volumes in the storage array.
volume
The name of a volume for which you are clearing persistent reservations. Enclose the volume name in square brackets ([ ]). If the volume name contains special characters or consists only of numbers, you must enclose the name in double quotation marks (" ") inside square brackets.
volumes
The names of several volumes for which you are clearing persistent reservations. Enter the names of the member volumes using these rules:
  • Enclose all of the names in square brackets ([ ]).
  • Enclose each of the names in double quotation marks (" ").
  • Separate each of the names with a space.
Notes
You can use any combination of alphanumeric characters, hyphens, and underscores for the names. Standard and thin volume names can have a maximum of 60 characters.
