SANtricity commands
Create host group - SANtricity CLI
Contributors netapp-driley
The create hostGroup command creates a new host group.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
create hostGroup userLabel="hostGroupName"
Parameter
Parameter Description
userLabel
The name that you want to give the host group that you are creating. Enclose the host group name in double quotation marks (" ").
Notes
A host group is an optional topological element that you can define if you want to designate a collection of hosts that share access to the same volumes. The host group is a logical entity. Define a host group only if you have two or more hosts that can share access to the same volumes.
You can use any combination of alphanumeric characters, hyphens, and underscores for the names. Names can have a maximum of 30 characters.
Minimum firmware level
5.20
