SANtricity commands
Create host port - SANtricity CLI
Contributors netapp-driley
The create hostPort command creates a new host port identification on a host bus adapter (HBA) or on a host channel adapter (HCA).
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
The host port identification is a software value that represents the physical HBA or HCA host port to the controller. Without the correct host port identification, the controller cannot receive instructions or data from the host port.
Syntax
create hostPort identifier=("wwID" | "gid")
userLabel="portLabel"
[host="hostName"]
[interfaceType=(FC | SAS | IB)]
Parameter Description
identifier
The 8-byte World Wide Identifier (WWID) or the 16-byte group identifier (GID) of the HBA or HCA host port. Enclose the WWID or the GID in double quotation marks (" ").
userLabel
The name that you want to give to the new HBA or HCA host port. Enclose the host port label in double quotation marks (" ").
host
The name of the host for which you are defining an HBA or HCA host port. Enclose the host name in double quotation marks (" ").
interfaceType
The identifier of the type of interface for the host port.
The choices for the types of host port interfaces are:
  • FC — Fibre Channel
  • SAS — Serial-Attached SCSI
  • IB — InfiniBand
An FC or a SAS selection requires an 8-byte WWID. An IB selection requires a 16-byte group identifier (GID).
If you do not specify the type of interface, FC is used as the default interface for the host port.
Notes
An HBA host port or an HCA host port is a physical connection on a host bus adapter or on a host channel adapter that resides in a host computer. An HBA host port or an HCA host port provides host access to the volumes in a storage array. If the HBA or the HCA has only one physical connection (one host port), the terms host port and host bus adapter or host channel adapter are synonymous.
You can use any combination of alphanumeric characters, hyphens, and underscores for the names. Names can have a maximum of 30 characters.
Minimum firmware level
5.20
7.10 deprecates the hostType parameter. The hostType parameter has been added to the create host command.
7.32 adds the interfaceType parameter.
