SANtricity commands
Create snapshot image - SANtricity CLI
Contributors netapp-driley
The create snapImage command creates a new snapshot image in one or more existing snapshot groups.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Before you can create a snapshot image, you must first have at least one snapshot group into which you can place the snapshot image. To create a snapshot group use the create snapGroup command.
Syntax
create snapImage (snapGroup="snapGroupName" |
snapGroups=("_snapGroupName1"... "snapGroupNamen"))
Parameter Description
snapGroup
The name of the snapshot group that will contain the snapshot image. Enclose the name of the snapshot group in double quotation marks (" ").
snapGroups
The names of several snapshot groups that will contain the snapshot image. Enter the names of the snapshot groups using these rules:
  • Enclose all of the names in parentheses.
  • Enclose each of the names in double quotation marks (" ").
  • Separate each of the names with a space.
Notes
You can use any combination of alphanumeric characters, underscore (_), hyphen (-), and pound (#) for the names. Names can have a maximum of 30 characters.
A snapshot image is a logical point-in-time image of the contents of an associated base volume. The snapshot image is created instantly and records the state of the base volume at that moment. Every snapshot image is created in the context of exactly one snapshot group. A snapshot group is a sequence of snapshot images of the associated base volume. A snapshot group has one repository volume used to save all of the data from the snapshot images. The snapshot images in a snapshot group have a specific order. The specific order of the snapshot images enables you to manage the snapshot images, such as restoring a specific snapshot image to the base volume or deleting the snapshot images that you no longer need.
The result of creating a snapshot image of a consistency group is a snapshot image of every member volume of the consistency group.
Minimum firmware level
7.83
