SANtricity commands
Create volume copy - SANtricity CLI
Contributors netapp-driley
The create volumeCopy command creates a volume copy and starts the volume copy operation. This command is valid for snapshot image volume copy pairs.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Note
Starting a volume copy operation overwrites all existing data on the target volume, makes the target volume read-only to hosts, and fails all snapshot image volumes associated with the target volume, if any exist. If you have used the target volume as a copy before, be sure you no longer need the data or have it backed up.
This command creates volume copies in two ways:
  • Volume copy without snapshot image, also called offline volume copy
  • Volume copy with snapshot image, also called online volume copy
If you use volume copy without snapshot image, you cannot write to the source volume until the copy operation is complete. If you want to be able to write to the source volume before the copy operation is complete, use volume copy with snapshot image. You can select volume copy with snapshot image through the optional parameters in the command syntax.
After completion of the volume copy with snapshot image operation, the snapshot image is deleted and the snapshot volume is disabled.
Note
You can have a maximum of eight volume copies in progress at one time. If you try to create more than eight volume copies at one time, the controllers return a status of Pending until one of the volume copies that is in progress finishes and returns a status of Complete.
Syntax
create volumeCopy source="sourceName"
target="targetName"
[copyPriority=(highest | high | medium | low | lowest)]
[targetReadOnlyEnabled=(TRUE | FALSE)]
[copyType=(offline | online)]
[repositoryPercentOfBase=(20 | 40 | 60 | 120 | default)]
[repositoryGroupPreference=(sameAsSource | otherThanSource | default)]
Parameter Description
source
The name of an existing volume that you want to use as the source volume. Enclose the source volume name in double quotation marks (" ").
target
The name of an existing volume that you want to use as the target volume. Enclose the target volume name in double quotation marks (" ").
copyPriority
The priority that volume copy has relative to host I/O activity. Valid values are highest, high, medium, low, or lowest.
The setting so that you can write to the target volume or only read from the target volume. To write to the target volume, set this parameter to FALSE. To prevent writing to the target volume, set this parameter to TRUE.
copyType
Use this parameter to create a volume copy with a snapshot image. Creating a volume copy with a snapshot image enables you to continue to write to the source volume while creating the volume copy. To create a volume copy with a snapshot image, set this parameter to online. To create a volume copy without a snapshot image, set this parameter to offline.
If you do not use this parameter, the volume copy is created without a snapshot image.
This parameter determines the size of the repository volume for the snapshot image when you are creating a volume copy with a snapshot image. The size of the repository volume is expressed as a percentage of the source volume, which is also called the base volume. Valid values for this parameter are 20, 40, 60, 120, and default. The default value is 20. If you do not use this parameter, the firmware uses a value of 20 percent.
You must use the copyType parameter with the repositoryPercentOfBase parameter.
This parameter determines to which volume group the snapshot image repository volume is written. You have these choices:
  • sameAsSource — The snapshot image volume is written to the same volume group as the source volume if space is available.
  • otherThanSource — Deprecated parameter. Do not use
  • default — The snapshot image repository volume is written to any volume group that has space.
For best performance, use the sameAsSource option.
You must use the copyType parameter with the repositoryGroupPreference parameter.
Notes
You can use any combination of alphanumeric characters, hyphens, and underscores for the names. Standard and thin volume names can have a maximum of 60 characters.
Copy priority defines the amount of system resources that are used to copy the data between the source volume and the target volume of a volume copy pair. If you select the highest priority level, the volume copy uses the most system resources to perform volume copy, which decreases performance for host data transfers.
