SANtricity commands
Delete email alert recipient - SANtricity CLI
Contributors netapp-driley
The delete emailAlert command deletes recipient email address(es) from the Email alert configuration.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Syntax
delete emailAlert
       (allEmailRecipients |
        emailRecipients [emailAddress1 ... emailAddressN])
Parameter Description
allEmailRecipients
Allows you to delete all email recipients.
emailRecipients
Allows you to delete the recipient addresses. Enclose the email addresses in square brackets ([ ]).
SMcli -n Array1 -c "delete emailAlert allEmailRecipients;"
SMcli -n Array1 -c "delete emailAlert emailRecipients ["person1@email.domain.com" "person3@email.domain.com"];"
SMcli completed successfully.
Minimum firmware level
8.40
