Delete storage array directory server - SANtricity CLI
The delete storageArray directoryServers command allows you to delete one or more directory servers.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Syntax
delete storageArray (allDirectoryServers |
directoryServers ["domainId1" ... "domainIdN")
| Parameter | Description | ||
Allows you to delete all directory servers. |
Allows you to specify one or more directory servers to delete, each identified with the domain ID.
SMcli -n Array1 -c "delete storageArray directoryServers ["domain1" "domain3"];" SMcli -n Array1 -c "delete storageArray allDirectoryServers;" SMcli completed successfully.
Minimum firmware level
8.40 adds the command.
