SANtricity commands
Remove installed trusted CA certificates - SANtricity CLI
Contributors netapp-driley netapp-maumita
The delete storageArray trustedCertificate command removes the specified user installed CA certificates from the array's web servers.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Syntax
delete storageArray trustedCertificate [(allUserInstalled |
aliases=("alias1" ... "aliasN"))]
Parameter Description
allUserInstalled
Allows you to specify the removal of all user installed certificates.
aliases
Allows you to specify one or more CA certificates to be deleted using the alias names or specify all. The aliases can be from any controllers. Enclose all the aliases in parentheses. If you enter more than one alias, separate them with a space.
SMcli -n Array1 -c "delete storageArray trustedCertificate allUserInstalled;"
   aliases=("19527b38-8d26-44e5-8c7f-5bf2ca9db7cf" "04bf744c-413a-49f1-9666-88d74189591d");"
SMcli completed successfully.
Minimum firmware level
8.40
