Delete syslog server - SANtricity CLI
The delete syslog command deletes one or more servers from the syslog configuration so that it no longer receives alerts.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Syntax
delete syslog (allServers | serverAddresses [serverAddress1 ... serverAddressN])
| Parameter | Description |
Allows the user to delete all syslog servers. |
Allows the user to delete the syslog servers. Enclose the servers in square brackets ([ ]). |
SMcli -n Array1 -c "delete syslog allServers; SMcli -n Array1 -c "delete syslog serverAddresses ["serverName1.company.com"]"; SMcli completed successfully.
Minimum firmware level
8.40
