Install server signed certificate - SANtricity CLI
The download controller arrayManagementServerCertificate command installs the server certificate on the controller.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Context
Perform this action for each controller using the signed certificate that is applicable to the controller. The signed certificate must include the controller's IPs/DNS names.
Syntax
download controller [(a|b)] arrayManagementServerCertificate file="filename"
| Parameter | Description |
Allows the user to specify the controller on which you want to install the server signed certificate for. Valid controller identifiers are a or b, where a is the controller in slot A, and b is the controller in slot B. Enclose the controller identifier in square brackets ([ ]). |
Allows the user to specify the file path and filename that contains the signed certificate. The acceptable extensions are .cer, .crt, .der. |
SMcli -n Array1 -c "download controller [a] arrayManagementServerCertificate file="C:\serverSignedCertificateA.cer";" SMcli -n Array1 -c "download controller [b] arrayManagementServerCertificate file="C:\serverSignedCertificateB.cer";" SMcli completed successfully.
Minimum firmware level
8.40
