SANtricity commands
Install trusted CA certificates - SANtricity CLI
Contributors netapp-driley netapp-maumita
The download controller trustedCertificate command installs the trusted CA certificates on the controllers' web servers to validate the LDAP server signed certificate.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Context
Perform this action only if the CA who signed the certificates is not well known or commonly trusted. The command installs the CA certificate on both controllers.
Syntax
download storageArray trustedCertificate [alias=string] file="filename"
Parameter Description
alias
Allows you to specify an alias to represent the trusted CA certificate. This alias is used to look up information about the trusted CA certificates or to delete them. An alias is associated to a trusted certificate and must be unique.
file
Allows you to specify the file that contains the trusted CA certificate. The acceptable extensions are .pem, .cer, .crt, and .der.
SMcli -n Array1 -c "download storageArray trustedCertificate alias="myAlias"
   file="C:\rootCA1.cer";"
SMcli completed successfully.
Minimum firmware level
8.40
