SANtricity commands
Install storage array external key management certificate - SANtricity CLI
Contributors netapp-driley netapp-maumita
The download storageArray keyManagementCertificate command installs the external key management certificates on the storage array.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Context
Note
This command applies only to external key management.
Syntax
download storageArray keyManagementClientCertificate certificateType=(client|server) file="filename" [privateKeyFile = "keyFileName"]
Parameter Description
certificateType
Allows you to specify the certificate file type. Valid choices are client or server.
file
Allows you to specify the client signed certificate or server root/intermediate CA certificate. The file must be in PEM/DER format.
privateKeyFile
Allows you to download a private key alongside a signed certificate. The privateKeyFile parameter must be used with certificateType=client value.
SMcli -n Array1 -c "download storageArray keyManagementClientCertificate certificateType=client
   file="C:\serverSignedKeyMgmtClientCert.cer";"
SMcli completed successfully.
Minimum firmware level
8.40
