SANtricity commands
Remove storage array directory server role mapping - SANtricity CLI
Contributors netapp-driley
The remove storageArray directoryServer command removes the defined role mappings for the specified directory server.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Syntax
remove storageArray directoryServer [domainId]
    (allGroupDNs | groupDNs=(groupDN1 ... groupDNN))
Parameter Description
directoryServer
Allows you to specify the domain, using the domain ID, for which to remove the mapping.
allGroupDNs
Allows you to remove all group Distinguished Name mappings from the domain.
groupDNs
Allows you to specify the groups' distinguished name (DN) to be removed.
Note
If you enter more than one group, separate the values with a space.
SMcli -n Array1 -c "remove storageArray directoryServer ["domain1"]
                    groupDNs=("CN=company-distlist,OU=Managed,
                    OU=MyCompanyGroups,DC=hq,DC=mycompany,DC=com");"
                    allGroupDNs;"
SMcli completed successfully.
