Remove synchronous mirroring - SANtricity CLI
The remove syncMirror command removes the mirror relationship between the primary volume and the secondary volume in a remote-mirrored pair.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, and E5700 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, or E5700 storage array, you must have the Storage Admin role.
Context
In previous versions of this command the feature identifier was |
Syntax
remove syncMirror (localVolume [volumeName] |
localVolumes [volumeName1 ... volumeNameN])
| Parameter | Description |
The name of the primary volume (the volume on the local storage array) that you want to remove. Enclose the volume name in square brackets ([ ]). If the volume name has special characters or consists only of numbers, you must enclose the volume name in double quotation marks (" ") inside square brackets. |
The names of several primary volumes (the volumes on the local storage array) that you want to remove. Enter the names of the primary volumes using these rules:
If the primary volume names have special characters or consist only of numbers, enter the names using these rules:
Minimum firmware level
6.10
