SANtricity commands
Repair data parity - SANtricity CLI
Contributors netapp-driley
The Repair Data Parity command repairs data parity errors.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Before utilizing this command, consult with NetApp Support for guidance on the affected firmware, drives, and RAID stripe.
Syntax
repair volume[volumeName] parity
   [startingLBA=LBAvalue]
   [endingLBA=LBAvalue]
   [repairMethods=(repairMethod . . . repairMethod)]
           Space delimited list where possible repair methods are: reconstruct, unmap, updateP, updateQ, updateData, and writeZeros
   [repairPI=(TRUE|FALSE)]
   [suspectDrives=(trayID1,[drawerID1,]slotID1 . . . trayIDn,[drawerIDn,]slotIDn)]
   [timeout=(0-65535)]
Parameter Description
volume
The name of the volume for which you are repairing parity. Enclose the volume name in square brackets ([ ])
startingLBA
The starting logical block address.
endingLBA
The ending logical block address.
repairMethods
The method used to repair the parity error. Available methods include:
  • reconstruct: Reconstructs drives specified under the suspectDrives parameter.
  • unmap: For R5/R6 dulbe volumes, used to make a R5/R6 RAID stripe unmapped
  • updateP: Used to fix the data parity mismatch type.
  • updateQ: Used to fix the data parity mismatch type.
  • updateData: Used to fix the data parity mismatch type.
  • writeZeros: For R5/R6 dulbe volumes, used when an unexpected RAID5/6 stripe containing a mix of mapped and unmapped data is found. Takes the unmapped blocks in the stripe and write zeros to it and then updates parity
repairPI
Set to TRUE to repair PI in the extent beginning at startingLBA.
suspectDrives
Used to specify the drives for reconstruction.
timeout
The length of time in minutes that you want to run the operation.
Minimum Firmware Level
8.63
