Resume snapshot image rollback - SANtricity CLI
The resume snapImage rollback command resumes a rollback operation that has entered a paused state.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
A rollback operation can enter a paused state due to processing errors, which causes a Needs Attention condition for the storage array.
If the rollback operation cannot be resumed, the selected snapshot image reverts to a paused state, and the Needs Attention condition is displayed.
You cannot use this command for snapshot images involved in online volume copy. |
Syntax
resume snapImage [snapImageName] rollback
Parameter
| Parameter | Description |
The name of the snapshot image for which you want to restart a rollback operation. The name of a snapshot image is comprised of two parts:
The identifier for the snapshot image can be one of these:
Enclose the snapshot image name in double quotation marks (" ") inside square brackets ([ ]). |
Notes
The name of a snapshot image has two parts separated by a colon (:):
The identifier of the snapshot group
The identifier of the snapshot image
For example, if you want to restart a rollback operation for snapshot image 12345 in a snapshot group that has the name snapgroup1, you would use this command:
resume snapImage ["snapgroup1:12345"] rollback;
Minimum firmware level
7.83
