Resume SSD cache - SANtricity CLI
The resume ssdCache command restarts the caching for all of the volumes using the SSD cache that was temporarily stopped with the suspend ssdCache command.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Support Admin role.
Syntax
resume ssdCache [ssdCacheName]
Parameter
| Parameter | Description |
The name of the SSD cache for which you want to resume caching operations. Enclose the SSD cache name in square brackets ([ ]). If the SSD cache name has special characters or consists only of numbers, you must enclose the SSD cache name in double quotation marks (" ") inside square brackets. |
Minimum firmware level
7.84
11.80 adds EF600 and EF300 array support
