SANtricity commands
Revive volume group - SANtricity CLI
Contributors netapp-driley
The revive volumeGroup command forces the specified volume group and its associated failed drives to the Optimal state.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Context
Note
Possible loss of data access — Correct use of this command depends on the data configuration on all of the drives in the volume group. Never try to revive a drive unless you are supervised by technical support.
Syntax
revive volumeGroup [volumeGroupName]
Parameter
Parameter Description
volumeGroup
The name of the volume group to be set to the Optimal state. Enclose the volume group name in square brackets ([ ]).
Minimum firmware level
6.10
