Save drive log - SANtricity CLI
The save allDrives logFile command saves the drive logs to a file.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Drive log data is maintained by the storage array for each drive.
Do not run this command unless you are instructed to do so by technical support. |
Syntax
save allDrives logFile="filename"
Parameter
| Parameter | Description | ||
The file path and the file name to which you want to save the drive logs. Enclose the file name in double quotation marks (" "). For example:
Minimum firmware level
6.10
