Retrieve installed server certificate - SANtricity CLI
The save controller arrayManagementCSR command retrieves the installed server Certificate Signing Request (CSR) for the controller so you can view certificate details.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Syntax
save controller [(a|b)] arrayManagementCSR file="filename"
| Parameter | Description |
Allows you to specify the controller on which you want to download the signed certificate from. Valid controller identifiers are a or b, where a is the controller in slot A, and b is the controller in slot B. Enclose the controller identifier in square brackets ([ ]). |
Allows you to specify the file for which to save the controller's signed certificate file. |
SMcli -n Array1 -c "save controller [a] aarrayManagementCSR file="C:\controllerAcertificate.cer";" SMcli -n Array1 -c "save controller [b] arrayManagementCSR file="C:\controllerBcertificate.cer";" SMcli completed successfully.
Minimum firmware level
8.40
