Save input output controller (IOC) dump - SANtricity CLI
The save IOCLog command saves the IOC dumps from the controllers in a storage array to a file on a host.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
save IOCLog [file="filename"]
Parameter
| Parameter | Description |
The file path and the file name to which you save the IOC dump. Enclose the file name in double quotation marks (" "). For example: file="C:\Array Backups\IOCcoredump1.7z" This command saves the data to a compressed file and adds the file extension |
Notes
This command retrieves from both controllers the IOC dump log data and the IOC dump metadata. Using a 7zip file format, the retrieved data is archived and compressed into a single file with a file name of your choice. The 7zip archive file contains the following:
filename+"IOCLog"+[A|B].gz — the IOC logs retrieved from controller A or controller B if available
filename+"IOCLogInfo"+[A|B].txt — the IOC logs metadata info retrieved from controller A or controller B . If the IOC log data cannot be retrieved from a controller, the metadata .txt file will contain the error condition and reason.
The following are error conditions:
The controller platform and HIC do not support IOC dump.
The controllers have not collected IOC dump data.
The compressed logs are not in a human-readable format. You must return the logs to technical support to be evaluated.
Minimum firmware level
8.20
