SANtricity commands
Save storage array configuration - SANtricity CLI
Contributors netapp-driley
The save storageArray configuration command creates a script file that you can use to re-create the current storage array volume configuration.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role. However, the use of this command with the LDAP parameter is restricted to those with the Security Admin role.
Context
Note
This command does not save remote mirroring or volume copy configuration data on the current storage array to a file.
Syntax
save storageArray configuration file="filename"
(allconfig|[globalSettings=(TRUE | FALSE)]
[volumeConfigAndSettings=(TRUE | FALSE)]
[hostTopology=(TRUE | FALSE)]
[lunMappings=(TRUE | FALSE)])
Parameter Description
file
The file path and the file name to which you want to save the configuration settings. Enclose the file name in double quotation marks (" "). For example:
file="C:\Program Files\CLI\logs\saconf.cfg"
The default name of the file that contains the configuration settings is storage-array-configuration.cfg. This command does not automatically append a file extension to the saved file. You must specify a file extension when entering the file name.
allConfig
The setting to save all of the configuration values to the file. (If you choose this parameter, all of the configuration parameters are set to TRUE .)
globalSettings
The setting to save the global settings to the file. To save the global settings, set this parameter to TRUE. To prevent saving the global settings, set this parameter to FALSE. The default value is TRUE.
The setting to save the volume configuration settings and all of the global settings to the file. To save the volume configuration settings and global settings, set this parameter to TRUE. To prevent saving the volume configuration settings and global settings, set this parameter to FALSE. The default value is TRUE.
hostTopology
The setting to save the host topology to the file. To save the host topology, set this parameter to TRUE. To prevent saving the host topology, set this parameter to FALSE. The default value is FALSE.
lunMappings
The setting to save the LUN or NSID mapping to the file. To save the LUN or NSID mapping, set this parameter to TRUE. To prevent saving the LUN or NSID mapping, set this parameter to FALSE. The default value is FALSE.
Notes
When you use this command, you can specify any combination of the parameters for the global setting, the volume configuration setting, the host topology, or the LUN mapping. If you want to enter all settings, use the allConfig parameter. You must either use the allConfig parameter, or one or more of the other four parameters.
Minimum firmware level
6.10
