SANtricity commands
Save storage array firmware inventory - SANtricity CLI
Contributors netapp-driley
The save storageArray firmwareInventory command saves a report to a file of all of the firmware currently running on the storage array.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
The report lists the firmware for these components:
  • Controllers
  • Drives
  • Drawers (if applicable)
  • Environmental services modules (ESMs)
  • Power supplies
You can use the information to help identify out-of-date firmware or firmware that does not match the other firmware in your storage array. You can also send the report to technical support for further review.
Syntax
save storageArray firmwareInventory file="filename"
Parameter
Parameter Description
file
The file path and the file name to which you want to save the firmware inventory. Enclose the file name in double quotation marks (" "). For example:
file="C:\Program Files\CLI\logs\fwinvent.txt"
The default name of the file that contains the firmware inventory is firmware-inventory.txt. This command does not automatically append a file extension to the saved file. You must specify a file extension when entering the file name.
Minimum firmware level
7.70
