Generate key management certificate signing request (CSR) - SANtricity CLI
The save storageArray keyManagementClientCSR command requests a generated CSR for the storage array that you can save to a file.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Context
This command applies only to external key management. |
Syntax
save storageArray keyManagementClientCSR commonName="common_name"
organization="organization"
locality="locality"
country="country"
file="file"
[organizationalUnit="organizational unit"]
[stateProvince="state_province"]
| Parameter | Description |
The value entered for this parameter must match one of the user names defined on the KMIP server. |
Allows you to specify the organization's full legal name that the storage array belongs to. Do not abbreviate it and include any suffixes such as Inc, Corp, or LLC. |
Allows you to specify the city or locality where the storage array is located, |
Allows you to specify your country's two-digit ISO (International Organization for Standardization) 3166-1 alpha-2 code, such as US. |
Allows you to specify the file and file location where you will save the controller's signed certificate file. |
Allows you to specify the organization's division that handles the certificate. |
Allows you to specify the state or region where the storage array is located. This should not be abbreviated. |
Example
SMcli -n Array1 -c "save storageArray keyManagementClientCSR commonName="192.0.2.1" organization="Widgets Are Us, Inc." locality="sedgwick" country="US" file="latestCertificate" organizationalUnit="Products Unit" stateProvince="Kansas";" SMcli completed successfully.
Minimum firmware level
8.40
