SANtricity commands
Save storage array performance statistics - SANtricity CLI
Contributors netapp-driley
The save storageArray performanceStats command saves the performance statistics to a file.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Before you use this command, run the set session performanceMonitorInterval command and the set session performanceMonitorIterations command to specify how often statistics are collected.
Syntax
save storageArray performanceStats file="filename"
Parameter
Parameter Description
file
The file path and the file name to which you want to save the performance statistics. Enclose the file name in double quotation marks (" "). For example:
file="C:\Program Files\CLI\logs\sastat.csv"
The default name of the file that contains the performance statistics is performanceStatistics.csv. You can use any file name, but you must use the .csv extension.
Minimum firmware level
6.10
