Save storage array RLS counts - SANtricity CLI
The save storageArray RLSCounts command saves the read link status (RLS) counters to a file.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
save storageArray RLSCounts file="filename"
Parameter
| Parameter | Description |
The file path and the file name to which you want to save the RLS counters. Enclose the file name in double quotation marks (" "). For example:
The default name of the file that contains the RLS counts is |
Notes
To more effectively save RLS counters to a file, perform these steps:
Run the
reset storageArray RLSBaselinecommand to set all of the RLS counters to 0. -
Run the storage array for a predetermined amount of time (for instance, two hours).
Run the
save storageArray RLSCounts file="filename" command.
Minimum firmware level
6.10
