SANtricity commands
Save storage array SAS PHY counts - SANtricity CLI
Contributors netapp-driley
The save storageArray SASPHYCounts command saves the SAS physical layer (SAS PHY) counters to a file.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
To reset the SAS PHY counters, run the reset storageArray SASPHYBaseline command.
Syntax
save storageArray SASPHYCounts file="filename"
Parameter
Parameter Description
file
The file path and the file name to which you want to save the SAS PHY counters. Enclose the file path and the file name in double quotation marks (" "). For example:
file="C:\Program Files\CLI\logs\sasphy.csv"
The default name of the file that contains the SAS PHY error statistics is sas-phy-error-log.csv. You can use any file name, but you must use the .csv extension.
Minimum firmware level
6.10
