SANtricity commands
Save storage array SOC counts - SANtricity CLI
Contributors netapp-driley
The save storageArray SOCCounts command saves the SOC error statistics to a file.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
This command is valid only for Fibre Channel devices in an arbitrated loop topology.
Syntax
save storageArray SOCCounts file="filename"
Parameter
Parameter Description
file
The file path and the file name to which you want to save the SOC error statistics. Enclose the file name in double quotation marks (" "). For example:
file="C:\Program Files\CLI\logs\socstat.csv"
The default name of the file that contains the SOC error statistics is soc-statistics.csv. You can use any file name, but you must use the .csv extension.
Notes
To more effectively save SOC error statistics to a file, perform these steps:
  1. Run the reset storageArray SOCBaseline command to set all of the SOC counters to 0.
  2. Run the storage array for a predetermined amount of time (for example, two hours).
  3. Run the save storageArray SOCCounts file="filename" command.
Minimum firmware level
6.16
