Retrieve installed trusted CA certificates - SANtricity CLI
The save storageArray trustedCertificate command retrieves the installed trusted CA certificates for the array. Included in the retrieved files are any requested CA certificates from the array's web servers.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Syntax
save storageArray trustedCertificate [allUserInstalled |
aliases=("alias1" ... "aliasN")] path="fileLocation"
| Parameter | Description |
Allows you to specify the retrieval of user installed certificates. The default option is |
Allows you to specify which user installed trusted certificate to retrieve by alias. Enclose all the aliases in parentheses. If you enter more than one alias, separate them with a space. |
Allows you to specify the local location for which to save the controller's trusted certificates. |
SMcli -n Array1 -c "save storageArray trustedCertificate allUserInstalled path="C:\";"
SMcli -n Array1 -c "save storageArray trustedCertificate aliases=("myAlias" "anotherAlias") path="C:\";"
SMcli completed successfully.
Minimum firmware level
8.40
