Set AutoSupport dispatch size limit - SANtricity CLI
The set storageArray autoSupport dispatchSizeLimit sets the maximum size of AutoSupport bundles and dispatches for different delivery types.
Through this command, users can configure the email size based on what their email server supports. Larger sizes reduce the chance of the support bundle being truncated.
Users should generally not configure HTTPS sizes unless directed by NetApp Support. |
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Syntax
set storageArray autoSupport dispatchSizeLimit (https=(<sizeInBytes>|unlimited)|email=(<sizeInBytes>|unlimited));
| Parameter | Description |
The maximum HTTPS dispatch size in bytes. If the maximum size is not configured, the default is 50 MiB. A value of "unlimited" or 0 allows for no size restriction. The minimum size allowed is 2 MiB.. |
The maximum email (SMTP) delivery size in bytes. If the maximum size is not configured, the default is 5 MiB. A value of "unlimited" or 0 allows for no size restriction. The minimum size allowed is 2 MiB. |
Minimum firmware level
8.90
