Add member to consistency group - SANtricity CLI
The set consistencyGroup addCGMemberVolume command adds a new base volume as a member to an existing consistency group.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
You can specify an existing repository volume for the new consistency group member, or create a new repository volume. When you create a new repository volume, you identify an existing volume group or an existing disk pool where you want the repository volume.
Syntax for use with an existing repository volume
set consistencyGroup ["consistencyGroupName"]
addCGMemberVolume="baseVolumeName"
repositoryVolume="volumeGroupName"
Syntax for use when creating a new repository volume in a volume group
repositoryVolume=("volumeGroupName" capacity=capacityValue(KB|MB|GB|TB|bytes))
Syntax for use when creating a new repository volume in a disk pool
repositoryVolume=("diskPoolName" capacity=capacityValue(KB|MB|GB|TB|bytes))
| Parameter | Description |
The name of the consistency group to which you want to add a new member volume. The new member volume is the base volume for snapshot operations. Enclose the consistency group name in double quotation marks (" ") inside square brackets ([ ]). |
The name of a base volume that you want to add. Enclose the volume name in double quotation marks (" "). If the specified volume is an existing repository volume or an existing snapshot volume, the command fails. |
This parameter performs two functions:
Enclose the volume name in double quotation marks (" "). |
The size of a new repository volume in either a volume group or a disk pool. Size is defined in units of bytes, KB, MB, GB, or TB. |
Notes
You can use any combination of alphanumeric characters, underscore (_), hyphen (-), and pound (#) for the names. Standard and thin volume names can have a maximum of 60 characters; all other component names can have a maximum of 30 characters.
A consistency group is a collection of base volumes that are the source volumes for snapshots. You collect the base volumes in a consistency group so that you can perform the same snapshot operations on each of the base volumes. In the context of this command, the term member means a base volume for snapshot operations. You can manipulate snapshot images associated with members of a consistency group through batch-style operations, while maintaining consistency across the snapshot images.
Each member volume must have a corresponding repository volume. You can define the relationship between the member volume and the repository volume using the repositoryVolume parameter. The repositoryVolume parameter can perform one of these actions:
Identify an existing repository volume that is connected to the consistency group.
Identify either a volume group or a disk pool in which you want to create a new repository volume.
Adding a member to a consistency group with an existing repository has two purposes:
You can create an entirely new repository volume by running the command without the
repositoryVolumeparameter. When you run the command without therepositoryVolumeparameter, the command creates a new repository volume in the volume group or disk pool in which all the other repository volumes are stored. An example of this command usage is:set consistencyGroup ["First_Images"] addCGMemberVolume="Data_020212"
You can reuse an existing repository volume if that repository volume is empty and is not related to another member volume. You might want to do this if you want to maintain a particular sequence or relationship for the repository volumes. To reuse an existing, empty repository volume you need to know the name of the repository volume. To determine the name of the repository volume use the
show allVolumes summarycommand. All repository volume names have the formrepos_XXXXwhereXXXXis a unique identifier generated by the storage management software. An example of this command usage is:set consistencyGroup ["First_Images"] addCGMemberVolume="Data_020212" repositoryVolume="repos_0011"
You can place the repository volume in a volume group or a disk pool of your choosing. You are not required to have the repository volume in the same location as other repository volumes. To place the repository volume in a volume group or a disk pool of your choice, use the repositoryVolume parameter and identify the volume group or the disk pool and a size for the repository volume. An example of this command usage is:
repositoryVolume=("12" capacity=2 GB)
In this example, "12" is the name of an existing volume group or an existing disk pool. The capacity parameter defines the size that you want for the repository volume group.
When you create a new repository volume in either a volume group or a disk pool, you must include parentheses around the volume group name and capacity, or the disk pool name and capacity.
Minimum firmware level
7.83
