Set host group - SANtricity CLI
The set hostGroup command renames a host group.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
set hostGroup [hostGroupName]
userLabel="newHostGroupName"
| Parameter | Description |
The name of the host group that you want to rename. Enclose the host group name in square brackets ([ ]). If the host group name has special characters or numbers, you must enclose the host group name in double quotation marks (" ") inside square brackets. |
The new name for the host group. Enclose the new host group name in double quotation marks (" "). |
Notes
You can use any combination of alphanumeric characters, hyphens, and underscores for the names. Names can have a maximum of 30 characters.
Minimum firmware level
6.10
