Set snapshot volume media scan - SANtricity CLI
The set snapVolume mediaScanEnabled command runs a media scan on the drives used for a snapshot volume.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Optionally, you also can perform a redundancy check on the data.
Syntax
set snapVolume ["snapVolumeName"]
mediaScanEnabled=(TRUE | FALSE) [redundancyCheckEnabled=(TRUE | FALSE)]
| Parameter | Description |
The name of the snapshot volume for which you are setting properties. Enclose the snapshot volume identifier in double quotation marks (" ") inside of square brackets ([ ]). |
The setting to turn on or turn off media scan for the snapshot volume. To turn on media scan, set this parameter to |
The setting to turn on or turn off redundancy checking during a media scan. To turn on redundancy checking, set this parameter to |
Notes
You can use any combination of alphanumeric characters, underscore (_), hyphen (-), and pound (#) for the names. Names can have a maximum of 30 characters.
Minimum firmware level
7.83
