SANtricity commands
Enable or disable AutoSupport maintenance window - SANtricity CLI
Contributors netapp-driley
The set storageArray autoSupportMaintenanceWindow command turns on or turns off the AutoSupport maintenance window feature.
Use a maintenance window to suppress automatic ticket creation on error events. Under normal operation mode the storage array will use AutoSupport to open a case with Technical Support if there is an issue. When AutoSupport is placed in a maintenance window this feature is suppressed.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Support Admin role.
Syntax
set storageArray autoSupportMaintenanceWindow (enable | disable)
    emailAddresses=("emailAddress1" "emailAddress2" ...)
    [duration=<duration_in_hours>];
Parameter Description
emailAddresses
The list of email addresses to receive a confirmation email that the maintenance window request has been processed. You can specify up to five email addresses.
duration
Optional. The duration (in hours) to enable maintenance window. If omitted, the maximum supported duration (72 hours) is used.
SMcli -n Array1 -c "set storageArray autoSupportMaintenanceWindow enable
      emailAddresses=\"me@company.com\" duration=5;"
SMcli completed successfully.
      emailAddresses=(\"me1@company.com\" \"me2@company.com\");"
SMcli -n Array1 -c "set storageArray autoSupportMaintenanceWindow disable
      emailAddresses=(\"me1@company.com\" \"me2@company.com\" \"me3@company.com\"
      \"me4@company.com\" \"me5@company.com\");"
Minimum Firmware Level
8.42
