Set storage array login banner - SANtricity CLI
The set storageArray loginBanner command allows you to upload a text file to be used as a login banner. The banner text can include an advisory notice and consent message, which is presented to users before they establish sessions in SANtricity System Manager or before they run commands.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Syntax
set storageArray loginBanner file="path_to_login_banner"
Context
After you load the text file, it is saved to the storage array. The banner text appears before the SANtricity System Manager login screen or before you run commands.
| Parameter | Description | ||
The file path and the file name where the login banner text file is stored.
Minimum firmware level
8.41
