Set storage array management interface - SANtricity CLI
The set storageArray managementInterface command changes the management interface of the controller. Change the management interface type to enforce confidentiality between the storage array and its management software or to access external tools.
Starting with SANtricity 12.00, this command is removed as the storage array will always operate in the restOnly=true mode.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Syntax
set storageArray managementInterface restOnly={true | false}
| Parameter | Description |
When set to When set to Some tools that communicate directly with the legacy management interface, such as the SANtricity SMI-S Provider or OnCommand Insight (OCI), will not work unless the |
SMcli -n Array1 -c "set storageArray managementInterface restOnly=true;" SMcli completed successfully.
Minimum firmware level
Not applicable.
