SANtricity commands
Set storage array redundancy mode - SANtricity CLI
Contributors netapp-driley
The set storageArray redundancyMode command sets the redundancy mode of the storage array to either simplex or duplex.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
set storageArray redundancyMode=(simplex | duplex)
Parameter
Parameter Description
redundancyMode
Use simplex mode when you have a single controller. Use duplex mode when you have two controllers.
Minimum firmware level
6.10
