Set certificate revocation check settings - SANtricity CLI
The set storageArray revocationCheckSettings command allows you to enable or disable revocation checking, and configure an Online Certificate Status Protocol (OCSP) server.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Context
The OCSP server checks for any certificates that the Certificate Authority (CA) has revoked before their scheduled expiration date. You might want to enable revocation checking in cases where the CA improperly issued a certificate or if a private key is compromised.
Make sure a DNS server is configured on both controllers, which allows you to use a fully qualified domain name for the OCSP server. |
After you enable revocation checking, the storage array denies an attempted connection to a server with a revoked certificate.
Syntax
set storageArray revocationCheckSettings ([revocationCheckEnable = boolean] &| [ocspResponderUrl=stringLiteral])
| Parameter | Description | ||
Set to |
The URL of the OCSP responder server to be used for the certificate revocation check.
Minimum firmware level
8.42
