Set tray attribute - SANtricity CLI
The set tray command sets user-defined attributes for an tray.
Syntax
set tray [trayID] (chassisName | assetTag)="userID"
| Parameter | Description |
Identifies a specific tray for which to set the attribute. Tray ID values are 0 to 99. You must put brackets ([ ]) around the enclosure ID value. |
Chassis name or number to give the new enclosure. Chassis names can be any combination of alphanumeric characters with a maximum length of 32 characters. Alphabetical characters can be uppercase or lowercase. You can also use the underscore character (_) and the hyphen (-) character. You cannot use spaces in a chassis name. You must put quotation marks (" ") around the chassis name. |
Asset tag name or number to give the new enclosure. Asset tags can be any combination of alphanumeric characters with a maximum length of ten characters. Alphabetical characters can be uppercase or lowercase. You can also use the underscore character (_) and the hyphen (-) character. You cannot use spaces in an asset tag name. You must put quotation marks (" ") around the asset tag name. |
Minimum firmware level
6.16
