Set volume copy - SANtricity CLI
The set volumeCopy target command defines the properties for a volume copy pair.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
With firmware version 7.83 the |
This command is valid for snapshot volume copy pairs.
Syntax
set volumeCopy target [targetName]
source [sourceName]
[copyPriority=(highest | high | medium | low | lowest)]
[targetReadOnlyEnabled=(TRUE | FALSE)]
| Parameter | Description | ||
The name of the volume to which the data will be copied. Enclose the target volume name in square brackets ([ ]). If the target volume name has special characters or numbers, you must enclose the target volume name in double quotation marks (" ") inside square brackets. |
The name of the volume from which the data will be copied. Enclose the source volume name in square brackets ([ ]). If the source volume name has special characters or numbers, you must enclose the source volume name in double quotation marks (" ") inside square brackets. |
The priority that the volume copy has relative to host I/O activity. Valid values are |
The setting so that you can write to the target volume or only read from the target volume. To write to the target volume, set this parameter to |
Notes
When you use this command, you can specify one or more of the optional parameters.
Minimum firmware level
5.40
7.83 removes the copyType=(online | offline) parameter.
