Set volume group forced state - SANtricity CLI
The set volumeGroup forcedState command moves a volume group into a Forced state.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Use this command if the start volumeGroup import command does not move the volume group to an Imported state or if the import operation does not work because of hardware errors. In a Forced state, the volume group can be imported, and you can then identify the hardware errors.
Syntax
set volumeGroup [volumeGroupName] forcedState
Parameter
| Parameter | Description |
The name of the volume group that you want to place in a Forced state. Enclose the volume group name in square brackets ([ ]). |
Notes
You can move the drives that comprise a volume group from one storage array to another storage array. The CLI provides three commands that let you move the drives. The commands are start volumeGroup export, start volumeGroup import, and set volumeGroup forcedState.
In the Forced state, you can perform an import operation on the volume group.
Minimum firmware level
7.10
