Show storage array controller health image - SANtricity CLI
The show storageArray controllerHealthImage command shows details of the controller health image on the controller cache, if a controller health image is available, on storage arrays that support the controller health image.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Context
With firmware version 8.20 the |
If the storage array does not support the controller health image feature, this command returns an error.
Syntax
None.
Minimum firmware level
7.83
8.20 replaces the coreDump parameter with the controllerHealthImage parameter.
