SANtricity commands
Show storage array host connectivity reporting - SANtricity CLI
Contributors netapp-driley
The show storageArray hostConnectivityReporting command returns the enablement status of the host connectivity reporting feature.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Syntax
None.
Minimum firmware level
8.42 New command parameter.
