Show storage array LUN mappings - SANtricity CLI
The show storageArray lunMappings command returns information from the storage array profile about the logical unit number (LUN) or namespace ID (NSID) mappings in the storage array.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Context
Default group LUN or NSID mappings are always shown. If you run this command without any parameters, this command returns all of the LUN or NSID mappings.
Syntax
show storageArray lunMappings (host ["hostName"] |
hostgroup ["hostGroupName"])
| Parameter | Description |
The name of a specific host for which you want to see the LUN or NSID mappings. Enclose the host name in double quotation marks (" ") inside of square brackets ([ ]). |
The name of a specific host group for which you want to see the LUN or NSID mappings. Enclose the host group name in double quotation marks (" ") inside of square brackets ([ ]). |
Notes
This command returns host topology information similar to this example.
MAPPINGS (Storage Partitioning - Enabled (0 of 16 used)) VOLUME NAME LUN CONTROLLER ACCESSIBLE BY VOLUME STATUS Access Volume 7 A,B Default Group Optimal 21 21 B Default Group Optimal 22 22 B Default Group Optimal
Minimum firmware level
6.10
