SANtricity commands
Show storage array ODX setting - SANtricity CLI
Contributors netapp-driley
The show storageArray odxsetting command returns the current settings for Offloaded Data Transfer (ODX) and VMware vStorage API Array Architecture (VAAI) on the storage array.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Context
The settings for this command can be one of the following:
  • True — ODX and VAAI are turned on.
  • False — ODX and VAAI are turned off.
  • Inconsistent — The controllers do not have the same settings.
  • Unknown — The setting for ODX or VAAI cannot be determined.
Syntax
None.
Notes
This command returns the ODX and VAAI information similar to this example.
Windows ODX Setting Status
odxEnabled  True | False | Inconsistent | Unknown
vaaiEnabled True | False | Inconsistent | Unknown
Minimum firmware level
8.20
