SANtricity commands
Display storage array syslog configuration - SANtricity CLI
Contributors netapp-driley
The show storageArray syslog command allows you to view the configuration of a syslog server used for storing audit logs. Configuration information includes a server ID, along with its address, protocol, and port number.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Syntax
show storageArray syslog (allServers | id="<id>")
Parameter Description
allServers
Displays all syslog configurations.
id
Displays the syslog configuration with the matching ID.
SMcli -n Array1 -c "show storageArray syslog allServers;"
SMcli -n Array1 -c "show storageArray syslog id=\"331998fe-3154-4489-b773-b0bb60c6b48e\";"
Server Address: 192.168.2.1.com
Port:           514
Protocol:       udp
Components
1. Component Name: auditLog
SMcli completed successfully.
Minimum firmware level
8.42
