SANtricity commands
Show storage array unreadable sectors - SANtricity CLI
Contributors netapp-driley
The show storageArray unreadableSectors command returns a table of the addresses of all of the sectors in the storage array that cannot be read.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Context
The returned table is organized with column headings for the following information:
  • Volume user label
  • Logical unit number (LUN)
  • Accessible by (host or host group)
  • Date/time
  • Volume-relative logical block address (hexadecimal format — 0xnnnnnnnn)
  • Drive location (tray t, slot s)
  • Drive-relative logical block address (hexadecimal format — 0xnnnnnnnn)
  • Failure type
The data is sorted first by the volume user label and second by the logical block address (LBA). Each entry in the table corresponds to a single sector.
Syntax
None.
Minimum firmware level
6.10
